Engineering ToolBox > Speed of Sound Formulas
Calculation formulas for velocity of sound in gas, fluid or solid
As a consequence of the compressibility of gases, fluids or solids, a disturbance introduced in some point of a substance will propagate through the substance with a finite velocity.
sound velocity
Acoustic Velocity and Speed of Sound
The velocity at which these small disturbances will propagate through the medium is called the Acoustic Velocity or the Speed of Sound.
The acoustic velocity is related to the change in pressure and density of the substance and can be expressed as
c = (dp / dρ)1/2 (1)
c = sound velocity (m/s, ft/s)
dp = change in pressure (Pa, psi)
dρ = change in density (kg/m3, lb/ft3)
Speed of Sound in Gases, Fluids and Solids
The acoustic velocity can alternatively be expressed as
c = (E / ρ)1/2 (2)
E = bulk modulus elasticity (Pa, psi)
This equation is valid for liquids, solids and gases. The sound travels faster through media with higher elasticity and/or lower density. If a medium is not compressible at all - incompressible - the speed of sound is infinite (c ≈ ∞).
Medium Properties at 1 bar and 0 oC
Substance Bulk Modulus Elasticity
- E
109 (N/m2)
Density
- ρ
(kg/m3)
Water 2.15 999.8
Oil 1.35 920
Ethyl Alcohol 1.06 810
Mercury 28.5 13595
Since the acoustic disturbance introduced in a point is very small, the heat transfer can be neglected and for gases assumed isentropic. For an isentropic process the ideal gas law can be used and the speed of sound can be expressed as
c = (k p / ρ)1/2
= (k R T)1/2 (3)
k = ratio of specific heats (adiabatic index)
p = pressure (Pa, psi)
R = gas constant
T = absolute temperature (oK, oR)
For an ideal gas the speed of sound is proportional to the square root of the absolute temperature.
Example - Speed of Sound in Air
The speed of sound in air at 0 oC and absolute pressure 1 bar can be calculated as
c = (1.4 287 273)1/2 = 331.2 (m/s)
k = 1.4
and
R = 287 (J/K kg)
The speed of sound in air at 20 oC and absolute pressure 1 bar can be calculated as
c = (1.4 287 293)1/2
= 343.1 (m/s)
Example - Speed of Sound in Water
The speed of sound in water at 0 oC can be calculated as
c = (2.06 109/999.8)1/2
= 1435.4 (m/s)
Ev= 2.06 109 (N/m2)
and
ρ = 999.8 (kg/m3)
Speed of Sound in Solids
Subsonic and Supersonic speed
