Engineering ToolBox > Heating Water by Injection Steam
For some applications a direct heating of a water substance by injecting steam directly may be convenient. A direct heating system is very simple since it don't require heat exchangers. Fouling of surfaces, which may be a major problem in certain processes, are avoided.
The steam flow rate in an steam injection process can be calculated as
ms = q / (hg - (t cp)) (1)
ms = steam flow rate (kg)
q = heat transfer rate (kW)
hg = specific total enthalpy of the steam before the control valve (kJ/kg)
t = final temperature of the water (oC)
cp = specific heat capacity of water (kJ/kg)
