Engineering ToolBox > Pressure Drop in Steam Pipes
Steam pipes and pressure drop diagrams - imperial and metric units
Pressure drop in steam pipes can be estimated with the diagrams below.
Imperial Units
steam pipe pressure drop diagram
The diagram is made for steam with pressure 100 psi. For other pressures use correction factors:
Pressure (psi) 0 5 10 30 60 90 100 110 150 200 250 300
Factor 6.9 5.2 4.3 2.4 1.5 1.1 1.0 0.92 0.70 0.55 0.45 0.38
Metric Units
steam pipe pressure drop diagram metric units
The diagram is made for steam with pressure  7 bar. For other pressures use correction factors:
Pressure (bar) 0 1 2 4 5 6 7 8.5 10 12 14 20
Factor 6.9 3.67 2.51 1.55 1.31 1.13 1.0 0.85 0.74 0.63 0.55 0.39
