Engineering ToolBox > Steam and Vapor Enthalpy
When a liquid evaporates its go through a process where
The heat transferred to a substance when temperature changes is often referred to as sensible heat. The heat required for changing state as evaporation is referred to as latent heat of evaporation.
The most common vapor is evaporated water - steam or moist.
Enthalpy of a system is defined as the mass of the system - m - multiplied by the specific enthalpy - h - of the system and can be expressed as:
H = m h (kJ) (1)
H = enthalpy (kJ)
m = mass (kg)
h = specific enthalpy (kJ/kg)
Specific enthalpy is a property of the fluid and can be expressed as:
h = u + p v (kJ/kg) (2)
u = internal energy (kJ/kg)
p = absolute pressure (N/m2)
v = specific volume (m3/kg)
Part of the water vapor - steam - properties can be expressed in a table as:
| p (bar) | ts (oC) | vf (m3/kg) | vg (m3/kg) | uf (kJ/kg) | ug (kJ/kg) | hf (kJ/kg) | hg (kJ/kg) | sf (kJ/kg.K) | sg (kJ/kg.K) |
| 0.006112 1) | 0.01 | 0.0010002 | 206.1 | 0 | 2,375 | 0.0006 | 2,501 | 0 | 9.155 |
| 0,010 | 7.0 | 0.0010001 | 129.2 | 29 | 2,385 | 29 | 2,514 | 0.106 | 8.974 |
| 1.01325 2) | 100.0 | 0.001044 | 1.673 | 419 | 2,507 | 419 | 2,676 | 1.307 | 7.355 |
| 220 | 373.7 | 0.00269 | 0.00368 | 1,949 | 2,097 | 2,008 | 2,178 | 4.289 | 4.552 |
| 221.2 3) | 374.15 | 0.00317 | 0.00317 | 2,014 | 2,014 | 2,084 | 2,084 | 4.430 | 4.430 |
Internal energy - u - can be calculated from (2) and is often omitted in tables. vf - change very little and is also often omitted.
Specific enthalpy of saturated water - hf - can be obtained from tables as above. The value depends on the pressure.
For saturated water at standard atmosphere - 2) -the specific enthalpy - hf - is 419 kJ/kg. At standard atmosphere - 1 bar (14.7 psi) - water starts boiling at 100 oC (212 oF).
The specific enthalpy of water (in SI units) can be calculated from:
hf = cw (tf - t0) (3)
hf = enthalpy of water (kJ/kg)
cw = specific heat of water = 4.19 (kJ/kg.oC)
tf = saturation temperature (oC)
t0 = refer temperature = 0 (oC)
Specific enthalpy of saturated steam - hg - can be obtained from tables as above. The value depends on the pressure.
For saturated steam at standard atmosphere - 2) - the specific enthalpy - hg - is 2,676 kJ/kg.
The specific enthalpy of evaporation can be calculated from:
he = hg - hf (4)
he = specific evaporation enthalpy (kJ/kg)
Specific evaporation enthalpy for water at standard atmosphere is:
he = 2,676 - 419 (kJ/kg)
= 2,257 (kJ/kg)
The specific enthalpy of superheated steam can be calculated from:
hs = hg + cps (ts - tf) (5)
hs = enthalpy of superheated steam (kJ/kg)
cps = specific heat of steam at constant pressure = 1.860 (kJ/kg.oC)
ts = superheated steam temperature (oC)
cps = 1.860 (kJ/kg.oC) at standard atmosphere. Be aware that cps varies with temperature.
