Engineering ToolBox > Steel Angles with Unequal Legs
Properties in imperial units of steel angles with unequal legs are indicated below.
| Size (mm x mm) | Dimensions | Static Parameters | |||||||
| Moment of Inertia | Section Modulus | ||||||||
| Depth h (mm) | With w (mm) | Thickness s (mm) | Sectional Area (cm2) | Weight (kg/m) | Ix (cm4) | Iy (cm4) | Wx (cm3) | Wy (cm3) | |
| 50 x 40 | 50 | 40 | 6 | 5.1 | 3.9 | 12.1 | 6.5 | 3.54 | 2.35 |
| 50 | 40 | 5 | 4.3 | 3.3 | 10.3 | 5.6 | 3.00 | 1.99 | |
| 60 x 30 | 60 | 30 | 6 | 5.1 | 4.0 | 18.2 | 3.0 | 4.78 | 1.32 |
| 60 | 30 | 5 | 4.3 | 3.3 | 15.6 | 2.6 | 4.04 | 1.12 | |
| 65 x 50 | 65 | 50 | 8 | 8.6 | 8.6 | 34.8 | 17.7 | 7.93 | 4.9 |
| 65 | 50 | 6 | 6.6 | 6.6 | 27.2 | 14.0 | 6.10 | 3.8 | |
| 65 | 50 | 5 | 5.5 | 5.5 | 23.2 | 11.9 | 5.14 | 3.2 | |
| 75 x 50 | 75 | 50 | 10 | 11.6 | 11.6 | 64 | 22.2 | 12.8 | 6.1 |
| 75 | 50 | 8 | 9.4 | 9.4 | 52 | 18.4 | 10.4 | 4.9 | |
| 75 | 50 | 6 | 7.2 | 7.2 | 41 | 14.4 | 8.0 | 3.8 | |
| 80 x 60 | 80 | 60 | 8 | 10.6 | 10.6 | 66 | 31.8 | 12.2 | 7.2 |
| 80 | 60 | 7 | 9.4 | 9.4 | 59 | 28.4 | 10.7 | 6.3 | |
| 80 | 60 | 6 | 8.1 | 8.1 | 51 | 24.8 | 9.3 | 5.5 | |
| 100 x 65 | 100 | 65 | 10 | 15.6 | 15.6 | 154 | 51 | 23.2 | 10.5 |
| 100 | 65 | 8 | 12.7 | 12.7 | 127 | 42 | 18.9 | 8.5 | |
| 100 | 65 | 7 | 11.2 | 11.2 | 113 | 38 | 16.6 | 7.5 | |
| 100 x 75 | 100 | 75 | 12 | 19.7 | 19.7 | 189 | 90 | 28.0 | 16.5 |
| 100 | 75 | 10 | 16.6 | 16.6 | 162 | 78 | 23.8 | 14.0 | |
| 100 | 75 | 8 | 13.5 | 13.5 | 133 | 64 | 19.3 | 11.4 | |
| 125 x 75 | 125 | 75 | 12 | 22.7 | 22.7 | 354 | 96 | 43.2 | 16.9 |
| 125 | 75 | 10 | 19.1 | 19.1 | 302 | 82 | 36.5 | 14.3 | |
| 125 | 75 | 8 | 15.5 | 15.5 | 247 | 68 | 29.6 | 11.6 | |
| 150 x 75 | 150 | 75 | 15 | 31.6 | 31.6 | 713 | 120 | 75 | 21.0 |
| 150 | 75 | 12 | 25.7 | 25.7 | 589 | 100 | 61 | 17.2 | |
| 150 | 75 | 10 | 21.6 | 21.6 | 501 | 86 | 52 | 14.6 | |
| 150 x 90 | 150 | 90 | 15 | 33.9 | 33.9 | 761 | 205 | 78 | 30.4 |
| 150 | 90 | 12 | 27.5 | 27.5 | 927 | 171 | 63 | 24.8 | |
| 150 | 90 | 10 | 23.2 | 23.2 | 533 | 146 | 53 | 21.0 | |
| 200 x 100 | 200 | 100 | 15 | 43 | 43 | 1758 | 299 | 137 | 38.4 |
| 200 | 100 | 12 | 34.8 | 34.8 | 1440 | 247 | 111 | 31.3 | |
| 200 | 100 | 10 | 29.2 | 29.2 | 1220 | 210 | 93 | 26.3 | |
| 200 x 150 | 200 | 150 | 18 | 60.0 | 60 | 2376 | 1146 | 174 | 103 |
| 200 | 150 | 15 | 50.5 | 50.5 | 2022 | 976 | 147 | 87 | |
| 200 | 150 | 12 | 40.8 | 40.8 | 1652 | 803 | 119 | 71 | |
