Engineering ToolBox > Steel Pipe - Expansion Loop Capacity
Steel pipes - thermal expansion and expansion loop capacities
The expansion loop is a common way to absorb the temperature expansion in steel pipes. Expansion loops can be fabricated from standard pipes and elbows.
steel pipe expansion loop
Approximate Expansion Capacity (mm)
Nominal Pipe Size (mm) Width of Expansion Loop - w - (m)
0.5 1.0 1.5 2.0 2.5
25 35 130
32 25 100 210
40 20 70 150
50   65 125 200
65   50 100 150 220
80   40 75 125 190
100   35 65 115 150
steel pipe temperature expansion loop diagram
