Engineering ToolBox > Heating Systems - Pressure Loss Diagram Steel Pipes
Pressure loss diagram hot water heating systems - steel pipes and tubes
The diagram below can be used to estimate the pressure loss in hot water piping heating systems.
hot water heating system pressure loss piping diagram
The heat flow is based on temperature difference 20oC.
Example - Pressure Loss in Hot Water Heating Pipe
The pressure loss in a 2" BS 1387 hot water heating pipe with heat flow 100 kW can be estimated as viewed below:
hot water heating system pressure loss diagram example
