Engineering ToolBox > Steel Pipes and Temperature Expansion
The maximum and minimum length of a pipe depends to the maximum and minimum temperature of the pipe - in cold (non operating) and running (operating) condition. The temperature expansion coefficient steel pipes per degree change of temperature is nearly constant:
The temperature expansion of carbon steel pipes expressed in inches per 100 feet per degree Fahrenheit:
The temperature expansion of carbon steel pipes expressed in mm per m per degree Celsius:
