Engineering ToolBox > Stress in Thick-Walled Tubes or Cylinders
Radial and tangential stress in thick-walled tubes or cylinders with closed ends - internal and external pressure
When a thick-walled tube or cylinder is subjected to internal and external pressure a hoop and longitudinal stress are produced in the wall.
Online Thick Walled Pipe & Cylinder Calculator
The calculator below can be used to calculate the stress in tick walled pipes or cylinders with closed ends.
inside pressure
outside pressure
inside radius
outside radius
radius to point in the wall
Stress in Axial Direction
The stress in axial direction at a point in the tube or cylinder wall can be expressed as:
σa = (pi ri2 - po ro2 )/(ro2 - ri2) (1)
σa = stress in axial direction (MPa, psi)
pi = internal pressure in the tube or cylinder (MPa, psi)
po = external pressure in the tube or cylinder (MPa, psi)
ri = internal radius of tube or cylinder (mm, in)
ro = external radius of tube or cylinder (mm, in)
Stress in Circumferential Direction - Hoop Stress
The stress in circumferential direction at a point in the tube or cylinder wall can be expressed as:
σc = [(pi ri2 - po ro2) / (ro2 - ri2)] - [ri2 ro2 (po - pi) / r2 (ro2 - ri2)] (2)
σc = stress in circumferential direction (MPa, psi)
r = radius to point in tube or cylinder wall (mm, in)
maximum stress when  r = ro (outside pipe or cylinder)
Stress in Radial Direction
The stress in tangential direction at a point in the tube or cylinder wall can be expressed as:
σr = [(pi ri2 - po ro2) / (ro2 - ri2)] + [ri2 ro2 (po - pi) / r2 (ro2 - ri2)] (3)
maximum stress when  r = ri (inside pipe or cylinder)
