Engineering ToolBox > Thermal Conductivity of some common Materials
Thermal conductivity of some common materials as aluminum, asphalt, brass, copper, steel and many more
Thermal conductivity is the quantity of heat transmitted through a unit thickness in a direction normal to a surface of unit area, due to a unit temperature gradient under steady state conditions.
Thermal conductivity, or heat transfer coefficients, of some common materials and products can be found in the table below:
Thermal Conductivity - k - (W/m K)
Material/Substance Temperature (oC)
25 125 225
Acetone 0.16
Acrylic 0.2
Air 0.024
Alcohol 0.17
Aluminum 250 255 250
Aluminum Oxide 30
Ammonia 0.022
Antimony 18.5
Argon 0.016
Asbestos-cement board 0.744
Asbestos-cement sheets 0.166
Asbestos-cement 2.07
Asbestos, loosely packed 0.15
Asbestos mill board 0.14
Asphalt 0.75
Balsa 0.048
Bitumen 0.17
Benzene 0.16
Beryllium 218
Brass 109
Brick dense 1.31
Brick work 0.69
Cadmium 92
Carbon 1.7
Cement, portland 0.29
Cement, mortar 1.73
Chalk 0.09
Cobalt 69
Concrete, light 0.42
Concrete, stone 1.7
Constantan 22
Copper 401 400 398
Corian (ceramic filled) 1.06
Corkboard 0.043
Cork, regranulated 0.044
Cork, ground 0.043
Cotton 0.03
Carbon Steel 54 51 47
Cotton Wool insulation 0.029
Diatomaceous earth (Sil-o-cel) 0.06
Earth, dry 1.5
Ether 0.14
Epoxy 0.35
Felt insulation 0.04
Fiberglass 0.04
Fiber insulating board 0.048
Fiber hardboard 0.2
Fireclay brick 500oC 1.4
Foam Glass 0.042
Gasoline 0.15
Glass 1.05
Glass, Pearls, dry 0.18
Glass, Pearls, saturated 0.76
Class, window 0.96
Glass, wool Insulation 0.04
Glycerol 0.28
Gold 310 312 310
Granite 1.7 - 4.0
Gypsum or plaster board 0.17
Hairfelt 0.05
Hardboard high density 0.15
Hardwoods (oak, maple..) 0.16
Helium 0.142
Hydrogen 0.168
Ice (0oC, 32oF) 2.18
Insulation materials 0.035 - 0.16
Iridium 147
Iron 80 68 60
Iron, wrought 59
Iron, cast 55
Kapok insulation 0.034
Kerosene 0.15
Lead Pb 35
Leather, dry 0.14
Limestone 1.26 - 1.33
Magnesia insulation (85%) 0.07
Magnesium 156
Marble 2.6
Mercury 8
Methane 0.030
Methanol 0.21
Mica 0.71
Mineral wool blanket 0.04
Molybdenum 138
Monel 26
Nickel 91
Nitrogen 0.024
Nylon 6 0.25
Oil, machine 0.15
Olive oil 0.17
Oxygen 0.024
Paper 0.05
Paraffin Wax 0.25
Perlite, atmospheric pressure 0.031
Perlite, vacuum 0.00137
Plaster, gypsum 0.48
Plaster, metal lath 0.47
Plaster, wood lath 0.28
Plastics, foamed 0.03
Plastics, solid
Platinum 70 71 72
Plywood 0.13
Polyethylene HD 0.42 - 0.51
Polypropylene 0.1 - 0.22
Polystyrene expanded 0.03
Porcelain 1.5
PTFE 0.25
PVC 0.19
Pyrex glass 1.005
Quarts mineral 3
Rock Wool insulation 0.045
Sand, dry 0.35
Sand, saturated 2.7
Sandstone 1.7
Sawdust 0.08
Silica aerogel 0.02
Silicone oil 0.1
Silver 429
Snow (temp < 0oC) 0.05 - 0.25
Sodium 84
Softwoods (fir, pine ..) 0.12
Steel 46
Stainless Steel 16 17 19
Straw insulation 0.09
Styrofoam 0.033
Tin Sn 67
Zinc Zn 116
Urethane foam 0.021
Vermiculite 0.058
Vinyl ester 0.25
Water 0.58
Water, vapor (steam) 0.016
Wood across the grain, white pine 0.12
Wood across the grain, balsa 0.055
Wood across the grain, yellow pine 0.147
Wood, oak 0.17
Wool, felt 0.07
