Engineering ToolBox > Thermoplastic Pipes - Temperature and Strength Derating
With increased temperature the strength of thermoplastic piping materials derates
Thermoplastic materials loose their strength to pressure and tension with increasing temperature. The table below can be used as a guide to common thermoplastics and their derated strength with temperature. Manufacturing data should always be consulted.
Derating Factor
Temperature PVDF CPVC PVC PB PEX PE
(oC) (oF)
21 70 1.0 1.0 1.0 1.0 1.0 1.0
27 80 0.9 1.0 0.9 1.0 0.9 0.9
32 90 0.9 0.9 0.8 0.9 0.9 0.9
38 100 0.8 0.8 0.6 0.9 0.9 0.8
43 110 0.8 0.8 0.5 0.8 0.8 0.8
49 120 0.7 0.7 0.4 0.8 0.8 0.7
54 130 0.7 0.6 0.3 0.7 0.8 0.5
60 140 0.6 0.5 0.2 0.7 0.7 0.4
66 150 0.6 0.5 1) 0.7 0.7 0.2
71 160 0.5 0.4 1) 0.6 0.7 1)
82 180 0.5 0.3 1) 0.5 0.6 1)
93 200 0.4 0.2 1) 0.4 0.5 1)
104 220 0.4 1) 1) 1) 1) 1)
121 250 0.4 1) 1) 1) 1) 1)
138 280 0.3 1) 1) 1) 1) 1)
1) The thermoplastic is not resistant for long term service at this temperature. Operating conditions should be avoided.
Plastic Pipes Temperature Derating Diagram
thermoplastic pipes effect of temperature on strength and stiffnes diagram
Example - Higher Temperature and Reduced Strength
If operating pressure for a 6" Schedule 80 CPVC pipe is 167 psi, the maximum operating pressure at 150oF (66oC) is reduced to
167 psi x 0.5 = 83.5 psi
