Engineering ToolBox > Thread Standards Used for Piping and Fluid Connectors
Thread designations and standards for threads used in piping and fluid connectors
Straight Pipes Standards
NPSC - American Standard Straight Pipe Threads in Pipe Couplings Couplings
Applicable Standards
NPSF - Dryseal American Standard Fuel Internal Straight Pipe Threads
NPSI - Dryseal American Intermediate Internal Straight Pipe Threads
NPSM - American Standard Straight Pipe Threads for Free-Fitting Mechanical Joints for Fixtures (these threads fit freely over NPTF threads. They are used in swivel nuts of 07 adapters)
Taper Pipe Standards
ANPT - Aeronautical National Taper Pipe Threads
NPT - American Standard Taper Pipe Threads for General Use
NPTF - Dryseal American Standard Taper Pipe Threads
PTF - SAE Short - Dryseal SAE Short Taper Pipe Threads
PTF - SAE Short is mainly used in low pressure pneumatic and fuel applications.
PTF SPL Short & SPL Extra Short - Dryseal Special Short Taper Pipe Threads
Are used in some pneumatic components where shortened thread depth is required because of size limitations.
AWWA - American Water Works Association
Unified Thread Standards
UN - Unified Constant Pitch Threads (standard series: 4, 6, 8, 12, 16, 20, 28, 32)
UNC - Unified Coarse Threads
UNEF - Unifed Extra Fine Threads
UNF - Unified Fine Threads
UNS - Unified Special Pitch Threads
UNJ - Unified Controlled Root Radius Threads
Metric Thread Standards
M - Metric Screw Threads M profile
M Keg Metric Taper Threads
Mainly used in Germany.
BSi - British Standards
R (BSPT) - British Standard Taper Pipe Threads, External
Rc (BSPT) - British Standard Taper Pipe Threads, Internal
Rp or G (BSPP) - British Standard Pipe (Parallel) Threads
Japanese Standards
PF - JIS Parallel Pipe Threads
PF threads are functionally interchangeable with BSPP. This is an old designations replaced with G.
PT - JIS Taper Pipe Threads
PT threads are functionally interchangeable with BSPT threads. This is an old designations replaced with and R and Rc.
PS - JIS Parallel Internal Pipe Threads (to mate with PT threads)
More about pipe thread standards.
