Engineering ToolBox > Vacuum - Required Evacuation Time
The evacuation time for a vacuum pump can be calculated as
t = V/q ln(p0/p1) (1)
t = evacuation time (s)
V = enclosed evacuated volume (m3, cu ft)
q = volume flow rate capacity of the vacuum pump (m3/s, cu ft/s)
p0 = initialization pressure - normal atmospheric pressure (mbar, mmHg)
p1 = end vacuum pressure (mbar, mmHg)
Note! Leakage through sealings etc. should be compensated by adjusting the volume flow rate of the vacuum pump.
(1) can be simplified to
t = V/q N (2)
N = natural log constant for the actual vacuum
N = 1 for vacuum up to 15 in Hg gauge
N = 2 for vacuum up to 22.5 in Hg gauge
N = 3 for vacuum up to 26 in Hg gauge
N = 4 for vacuum up to 28 in Hg gauge
Evacuation time of 1 m3 volume, evacuated to 500 mbar abs - vacuum pump volume flow capacity 0.1 m3/s - can be calculated as:
t = 1 (m3)/0.1 (m3/s) ln(1000 (mbar)/500 (mbar))
= 6.9 s
Evacuation to 100 mbar abs:
t = 1 (m3)/0.1 (m3/s) ln(1000 (mbar)/100 (mbar))
= 23 s
Evacuation to 10 mbar abs:
t = 1 (m3)/0.1 (m3/s) ln(1000 (mbar)/10 (mbar))
= 46 s
The calculator below can be used to calculate the vacuum evacuation time.
