Engineering ToolBox > Vacuum - Expanded Air Ratio
Converting standard air volume flow to actual air volume flow
Standard air volume flow - SCFM - can be converted to actual air volume flow - ACFM - with the expanded air ratio equation
EAR = 30 / P x (T + 460)/520 (1)
EAR = ACFM / SCFM = expanded air ratio - ratio between actual air volume flow - ACFM - and standard air volume flow - SCFM
P = absolute vacuum pressure (inches Hg) where 29.92 inches Hg is normal atmospheric pressure and 0 inches Hg is absolute vacuum
T = temperature (oF)
Actual air volume flow can be calculated by multiplying standard air volume with the expanded air ratio.
Expanded air ratios for temperatures 60oF (15.5oC) are indicated in the diagram below:
vacuum - expanded air ratio - diagram
The diagram above can be used to calculate air flow in SI-units where
The relation between vacuum in % and other pressure units are indicated in
