Engineering ToolBox > Vacuum and Flow Measurement
Measuring volume flow in vacuum
For standard or normal pressure it is common to measure flow in
At vacuum the air or gas is expanded and it is common to use
Since the gas is expanded, actual flow is greater than standard flow for the same gas flow.
The flow volume can be converted from standard volume flow to actual volume flow by the expression:
qa = qs (29.92/p) ((t + 460)/520) (1)
qa = actual volume flow (acfm)
qs = standard volume flow (scfm)
p = actual pressure (in Hg)
t = temperature (oF)
Conversion Factor from scfm to acfm (or nl/s to al/s)
Pressure TemperatureoF
in Hg absolute in Hg gauge Kpa absolute 0 30 60 90 120 150
29.92 0.00 101.42 0.88 0.94 1.00 1.06 1.12 1.17
28.92 1.00 98.03 0.92 0.97 1.03 1.09 1.15 1.21
27.92 2.00 94.64 0.95 1.01 1.07 1.13 1.20 1.26
26.92 3.00 91.25 0.98 1.05 1.11 1.18 1.24 1.30
25.92 4.00 87.86 1.02 1.09 1.15 1.22 1.29 1.35
24.92 5.00 84.47 1.06 1.13 1.20 1.27 1.34 1.41
23.92 6.00 81.08 1.11 1.18 1.25 1.32 1.40 1.47
22.92 7.00 77.69 1.15 1.23 1.31 1.38 1.46 1.53
21.92 8.00 74.31 1.21 1.29 1.36 1.44 1.52 1.60
20.92 9.00 70.92 1.27 1.35 1.43 1.51 1.60 1.68
19.92 10.00 67.53 1.33 1.42 1.50 1.59 1.68 1.76
18.92 11.00 64.14 1.40 1.49 1.58 1.67 1.76 1.86
17.92 12.00 60.75 1.48 1.57 1.67 1.77 1.86 1.96
16.92 13.00 57.36 1.56 1.67 1.77 1.87 1.97 2.07
15.92 14.00 53.97 1.66 1.77 1.88 1.99 2.10 2.20
14.92 15.00 50.58 1.77 1.89 2.01 2.12 2.24 2.35
13.92 16.00 47.19 1.90 2.03 2.15 2.27 2.40 2.52
12.92 17.00 43.80 2.05 2.18 2.32 2.45 2.58 2.72
11.92 18.00 40.41 2.22 2.37 2.51 2.65 2.80 2.94
10.92 19.00 37.02 2.42 2.58 2.74 2.90 3.06 3.21
9.92 20.00 33.63 2.67 2.84 3.02 3.19 3.36 3.54
8.92 21.00 30.24 2.97 3.16 3.35 3.55 3.74 3.93
7.92 22.00 26.85 3.34 3.56 3.78 4.00 4.21 4.43
6.92 23.00 23.46 3.82 4.07 4.32 4.57 4.82 5.07
5.92 24.00 20.07 4.47 4.76 5.05 5.35 5.64 5.93
4.92 25.00 16.68 5.38 5.73 6.08 6.43 6.78 7.13
3.92 26.00 13.29 6.75 7.19 7.63 8.07 8.51 8.95
2.92 27.00 9.90 9.06 9.66 10.25 10.84 11.43 12.02
1.92 28.00 6.51 13.79 14.68 15.58 16.48 17.38 18.28
0.92 29.00 3.12 28.77 30.65 32.52 34.40 36.27 38.15
0.82 29.10 2.78 32.28 34.38 36.49 38.59 40.70 42.80
0.72 29.20 2.44 36.76 39.16 41.56 43.95 46.35 48.75
0.62 29.30 2.10 42.69 45.47 48.26 51.04 53.83 56.61
0.52 29.40 1.76 50.90 54.22 57.54 60.86 64.18 67.50
0.42 29.50 1.42 63.02 67.13 71.24 75.35 79.46 83.57
0.32 29.60 1.08 82.71 88.11 93.50 98.89 104.29 109.68
0.22 29.70 0.75 120.31 128.15 136.00 143.85 151.69 159.54
0.12 29.80 0.41 220.56 234.95 249.33 263.72 278.10 292.49
