Engineering ToolBox > Valves - Typical Operating Ranges
Different types of valves and their operating ranges
The table below can be used as an indication of the different valve types and typical operating ranges.
Type of Valve Minimum Size Maximum Size
mm inches mm inches
Ball 6 1220 48
Butterfly 50 2 1830 72
Butterfly Neck 25 1 1830 72
Gate 3 1/8 1220 48
Globe 3 1/8 760 30
Plug Lubricated 6 760 30
Plug non lubricated 6 406 16
Swing Check 6 610 24
Swing Check Y-type 6 150 6
Lift Check 6 250 10
Tilting disc 50 2 760 30
Diaphragm 3 1/8 610 24
Y Oblique 3 1/8 760 30
Slide 50 2 1900 75
Pinch 25 1 305 12
Needle 3 1/8 25 1
