Engineering ToolBox > Vapor Pressure
The vapor pressure of a liquid is defined as the pressure exerted by the molecules that escapes from the liquid to form a separate vapor phase above the liquid surface.
The pressure exerted by the vapor phase is called the
The pressure depends on the temperature.
If a fluid consist of more than one component (a solution), the component with
At atmospheric pressure the saturation temperature of
