Engineering ToolBox > Vector Addition
In mechanics there are two kind of quantities
When adding vector quantities, both magnitude and direction are important. Common methods adding coplanar vectors (vectors acting in the same plane) are
The procedure of "the parallelogram of vectors addition method" is
The procedure of "the triangle of vectors addition method" is
The resulting vector of two coplanar vector can be calculated by trigonometry using "the cosine rule" for a non-right-angled triangle.
FR = [ F12 + F22 − 2 F1 F2 cos(180o - (α + β)) ]1/2 (1)
F = the vector quantity - force, velocity etc.
α + β = angle between vector 1 and 2
The angle between the vector and the resulting vector can be calculated using "the sine rule" for a non-right-angled triangle.
α = sin-1 [ F1 sin(180o - (α + β)) / FR ] (2)
α + β = the angle between vector 1 and 2 is known
A force 1 of magnitude 5 kN is acting in a direction 80o from a force 2 of magnitude 8 kN.
The resulting force can be calculated as
FR = [ (3(kN))2 + (8(kN))2 - 2 5(kN) 8(kN) cos(180o - (80o)) ]1/2
= 9 kN
The angle between vector 1 and the resulting vector can be calculated as
α = sin-1[ 3(kN) sin(180o - (80o)) / 9(kN) ]
= 19.1o
The angle between vector 2 and the resulting vector can be calculated as
α = sin-1[ 8(kN) sin(180o - (80o)) / 9(kN) ]
= 60.9o
The generic calculator below can used to add vectors for velocity, forces etc.
