Engineering ToolBox > Ventilation Principles
Some commonly used ventilation principles - the short cut, mixed air, displacement and piston principle
Ventilation systems may be classified according their ability to supply and withdraw air from the rooms ventilated. It is common to differentiate between the
The Short Cut Principle
The ventilation system is "short cut" when the make up air is withdrawn from the room before it has been in the people operating zones.
shortcut ventilation
A "short cut" will reduce the efficiency of the ventilation system, has no mission, and is in general avoided.
The Mixed Principle
With a ventilation system based on the mixed principle, make up air is supplied to the room with high speed, and/or local fans are used to mix the air in the room to an homogenous mass.
mixed ventilaton
The mixed principle is
The Displacement Principle
With the displacement principle heat and pollution is transferred from the residence zone close to the floor, up to the ceiling where it's evacuated through the outlet system.
displacement ventilation
Make up air is supplied with low velocity very close to the floor. The supply air is normally colder than the average air in the residence zone. The evacuated air close to the ceiling is warmer than the average air in the residence zone.
Activities in the room, people and machines, creates convective air flows from the floor to the ceiling:
The displacement ventilation system is suited for ventilation and cooling systems. The system is not suited for heating.
The Piston Principle
In a ventilation system based on the piston principle, the supply air moves through the rooms as a piston.
piston ventilation
The piston principle can be regarded as an extreme variant of the displacement system with a minimum of turbulence in the air flow through the room.
Note! To keep the flow "laminar" and stable the air velocity through the room should not be below 0.25 m/s. This require relatively large volume flows.
