Engineering ToolBox > Ventilation Filters
Ventilation filters may be classified and characterized after
Common dust concentrations exposed to filters in ventilation and air-condition systems
Felt, cloth, cellulose, glass, silk etc. without adhesive liquid
Flat Panel type - disposable Filters
- Air velocity 0.1 - 1.0 m/s
- Resistance 25 - 250 N/m2
- Efficiency 20-35%
Continuous roll - self cleaning Filters
- Air velocity 2.5 m/s
- Resistance 30 - 175 N/m2
- Efficiency 25%
Bag Filters
- Efficiency 40-90%
HEPA (High Efficiency Particulate Air) Filters
- Efficiency 99.97% for 0.3 micron particles and larger
ULPA (Ultra Low Penetrating Air) Filters
- Efficiency 99.9997 for 0.12 micron particles or larger
Panel type - cloth with viscous fluid coating - washable or disposable
- Plates about 500 mm x 500 mm
- Air velocity 1.5 - 2.5 m/s
- Resistance 20 - 150 N/m2
Continuous roll - continuously moving, self cleaning
| Filter | General properties | Class | Effect | Applications |
| Basis filters | In general: - produced in synthetic fibers - efficient for particles > 4-5 mm - air speed < 2.5 m/s - start pressure drop approximately 50 Pa - final pressure drop approximately 150 Pa | EU1 | Protects against insects and fibers. Limited effect against larger pollen (<70%) Ineffective against smoke and blacking particles | Window units Heat exchangers Air heaters Fiber filters in textile industry |
| EU2 | Effective against larger pollen (>85%) and larger atmospheric dust. Limited effect against dust and blacking particles | Heating and cooling units in electrical transformers garages industrial halls offices in industry | ||
| EU3 | Effective against larger pollen (>85%) and larger atmospheric dust. Limited effect against dust and blacking particles | Heating and cooling units in electrical transformers garages industrial halls offices in industry | ||
| EU4 | Limited effect against dust and blacking particles | In addition to EU3 kitchens and spray paint work shops | ||
| Fine filters | In general: - produced in glass fibers - efficient for particles > 0.1 mm - air speed < 2- 3 m/s - start pressure drop approximately 50-100 Pa - final pressure drop approximately 200 -250 Pa | EU5 | Effective against pollen and finer atmospheric dust Considerable effect against smoke. No effect against tobacco smoke | Churches, sport halls, department stores, schools, hotels Food stores |
| EU6 | As EU5 | As EU5 | ||
| EU7 | Effective against pollen and blacking dust | As EU6 and food industry, laboratories, theatres, hospital rooms, data rooms | ||
| EU8 | Very effective against particles and blacking. Very effective against microbes. Effective against tobacco smoke. | Operating theatres, production rooms for fine optics and electronics. Hospital examination rooms. | ||
| EU9 | As EU8 | As EU8 | ||
| Micro filters | In general: - produced in glass fibers in combination with separators of paper, plastic or aluminum - efficient for particles > 0.01 mm - air speed < 0.5 - 1.0 m/s - start pressure drop approximately 250 Pa - final pressure drop according life span and economy | EU10 | ||
| EU11 | ||||
| EU12 | ||||
| EU13 | ||||
| EU14 |
