Engineering ToolBox > Weber Number
An introduction to and a definition of the Weber Number
The Weber Number is a dimensionless value useful for analyzing fluid flows where there is an interface between two different fluids.
The Weber Number is the ratio between the inertial force and the surface tension force, and can be expressed as
We = ρ v2 l / σ (1)
We = Weber number (dimensionless)
ρ = density of fluid (kg/m3, lb/ft3)
v = velocity of fluid (m/s, ft/s)
l = characteristic length (m, ft)
σ = surface tension (dyne/cm)
Since the Weber Number represents an index of the inertial force to the surface tension force acting on a fluid element, it can be useful analyzing thin films flows and the formation of droplets and bubbles.
