Engineering ToolBox > Williams Hazens Equation of Pressure Drop
The Hazen-Williams equation can be used to calculate pressure drop (psi) in pipes or tubes due to friction
The Hazen-Williams formula for calculating head loss in pipes and tubes due to friction can be expressed as:
Pd = 4.52  q1.85 / (c1.85 dh4.8655) (1)
Pd = pressure drop (psi/ft pipe)
c = design coefficient determined for the type of pipe or tube - the higher the factor, the smoother the pipe or tube
q = flow rate (gpm)
dh = inside hydraulic diameter (inch)
Note! The Hazen-Williams formula gives accurate head loss due to friction for fluids with kinematic viscosity of approximately 1.1 cSt. More about fluids and kinematic viscosity.
The results for the formula is acceptable for cold water at 60 oF (15.6 oC) with kinematic viscosity 1.13 cSt. For hot water with a lower kinematic viscosity (0.55 cSt at 130 oF (54.4 oC)) the error will be significant.
Since the Hazen Williams method is only valid for water flowing at ordinary temperatures between 40 to 75 oF, the Darcy Weisbach method should be used for other liquids or gases.
Online Hazens-Williams Calculator
The calculator below can used to calculate the head loss:
l - pipe or tube length (ft)
c - design coefficient determined for the type of pipe or tube
q - flow rate (gal/min)
dh - hydraulic diameter (inch)
The Design Factor - c
The design factor is determined for the type of pipe or tube used:
