Engineering ToolBox > Wind Power
Theoretically available power in the wind can be expressed with the formula
P = 1/2 ρ A v3 (1)
P = power (W)
ρ = density of air (kg/m3)
A = area wind passing through perpendicular to the wind (m2)
v = wind velocity (m/s)
Be aware that the density of air decreases with temperature and altitude. Note that the major factor is the wind velocity. A 20% increase in wind velocity increases the power generation with 73%.
Theoretical and rated wind power generation for typical windmills are indicated in the "wind speed-power curve" below. Cut-in wind speed, rated wind speed, shut-down wind speed and rated power for windmills with 20% and 40% efficiency are indicated.�
can be expressed as
Pa = 1/2 ρ μ A v3 (2)
μ = efficiency of the windmill (in general less than 0.4, 40%)
The calculator below can be used to calculate available power from windmills:
The energy generated by a windmill depends on the power generation as indicated above - and how often, or how many hours the wind blows - or more scientifically - the "wind speed frequency distribution" at the actual location.
The total energy generated over a year can be calculated by summarizing the power generation for all velocities (ranging from the actual windmill cut-in speed to the shut-down speed) multiplied with the no. of hours the wind blows at the actual speeds.
A typical wind speed frequency distribution diagram with energy produced at the different velocities are indicated below.
