Engineering ToolBox > Wire Gauges
The common US wire gauges - AWG gauges
The AWG - American Wire Gauge - is used as a standard method of denoting wire diameter, measuring the diameter of the conductor (the bare wire) with the insulation removed. AWG is sometimes also known as Brown and Sharpe (B&S) Wire Gauge.
The higher the number - the thinner the wire. Typical household wiring is AWG number 12 or 14. For telephone wires there are common with AWG 22, 24, or 26.
AWG Diameter
(mm)
Diameter
(in)
Square
(mm2)
Resistance
(ohm/1000m)
40 0.08 . 0.0050 3420
39 0.09 . 0.0064 2700
38 0.10 0.0040 0.0078 2190
37 0.11 0.0045 0.0095 1810
36 0.13 0.005 0.013 1300
35 0.14 0.0056 0.015 1120
34 0.16 0.0063 0.020 844
33 0.18 0.0071 0.026 676
32 0.20 0.008 0.031 547
30 0.25 0.01 0.049 351
28 0.33 0.013 0.08 232.0
27 0.36 0.018 0.096 178
26 0.41 0.016 0.13 137
25 0.45 0.018 0.16 108
24 0.51 0.02 0.20 87.5
22 0.64 0.025 0.33 51.7
20 0.81 0.032 0.50 34.1
18 1.02 0.04 0.82 21.9
16 1.29 0.051 1.3 13.0
14 1.63 0.064 2.0 8.54
13 1.80 0.072 2.6 6.76
12 2.05 0.081 3.3 5.4
10 2.59 0.10 5.26 3.4
8 3.25 0.13 8.30 2.2
6 4.115 0.17 13.30 1.5
4 5.189 0.20 21.15 0.8
2 6.543 0.26 33.62 0.5
1 7.348 0.29 42.41 0.4
0 8.252 0.33 53.49 0.31
00 (2/0) 9.266 0.37 67.43 0.25
000 (3/0) 10.40 0.41 85.01 0.2
0000 (4/0) 11.684 0.46 107.22 0.16
The higher the gauge number, the smaller the diameter, and the thinner the wire.
Because of less electrical resistance a thick wire will carry more current with less voltage drop than a thin wire. For a long distance it may be necessary to increase the wire diameter - reducing the gauge - to limit the voltage drop.
