Engineering ToolBox > Work
The amount of work done is the product of the applied force and the distance
When a body is moved as a result of a force being applied to it, work is done.
The amount of work is the product of the applied force and the distance:
W = F s (1)
W = work done (J)
F = force acting on the object (N)
s = distance object moved in the direction of the force (m)
The unit of work is joule, J, which is defined as the amount of work done when a force of 1 Newton acts for distance of 1 m in the direction of the force.
1 J = 1 Nm
This is the same unit as energy.
The work done by a constant force and a spring force can be visualized as the area under the graph in distance force diagrams like
work - force and distance diagram constant and spring force
Example - Constant Force
A constant force of 20 N is acting a distance of 30 m. The work done can be calculated as
W = 20 (N) 30 (m)
    = 60 (J, Nm)
Example - Spring Force
A spring is extended 40 mm by a force of 20 N. The work done can be calculated as
W = 1/2 20 (N) 0.040 (m)
    = 0.4 (J, Nm)
